Ga door naar hoofdinhoud
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 Vragen Bekijk alle
Screen adhesive iPad mini 2
Hi, is it ok to use b7000 glue to adhere the screen down? I found using the adhesive strips don’t hold up to well over time. I heard the adhesive strips by bowler tech is good but since I have b7000 sitting here I wanted to see if that will be good enough.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Yeah the pre-applied adhesive strips generally aren’t enough I put B7000 liquid glue on the corners.
The bottom right definitely needs it because the ribbon cable for the digitizer pushes the screen up overtime so some liquid glue there will help.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Ok perfect thanks.
door
Voeg je antwoord toe
John Nguyen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 270
