Why there’s a blue Tint on my iMac Screen?
Hello I’ve recently upgraded my HDD in my 20 inch 2009 iMac’ but after replacing everything, the screen took a blue tint, and I don’t know how to resolve it, thanks for your Help
Is dit een goede vraag?
@Taha Khetib - Did replacing the cable fix things?
Was dit antwoord nuttig?
For the moment I'm still waiting to receive the LVDS cable, I will let you know as soon as I receive it !
So i’ve tested with a new cable but nothing, screen is Still blue
@Taha Khetib - I think that points to a bad T-CON board that’s the logic board sitting on the backside of the display assembly. You might be able to scare up one but you’ll need to get to yours to properly ID which board you have.
Oook I see, if i purchase a new display will it be ok ?
@Taha Khetib - Yes, that should fix things!
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 95
What does an external display look like?
door Dan
@I don’t have any external display with DisplayPort and any adapter, Can AirPlay count as a external display or iPad with a software like XDisplay ?
door Taha Khetib
Sadly, that's using a remote connection to the system, not accessing the GPU logic directly.
door Dan
@danj I see, but how Can i test the GPU, and know if it's a GPU problem or this is the screen ?
door Taha Khetib
Using an external monitor is all there is.
door Dan
