Ga door naar hoofdinhoud
Repair guides and disassembly information for Microsoft's third-gen Surface Laptop, released in October of 2019.
26 Vragen Bekijk alle
Replacing the palm rest...?
Is the base identical between the all metal and alcantara models? I would love to get the Cobalt Blue model, and then replace the alcantara palm rest with the matte black metal palm rest (seeing as it’s so easy to remove/replace). Would this be possible?
Is dit een goede vraag?
Score 1
2 opmerkingen
Hi, did you find a solution to this ? I want to do the same thing (replace my Alcantara cover with a metal one)
door
Same. Alcantara is not resillient enough
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
This question is asked on multiple different forums but none seem to have a definitive answer.
Doing some research by watching teardown video’s and photo’s will give you a good indication and then you just have to go for it.
And if it’s an easy task to replace the keyboard you can order a new one somewhere with the option to return it. You take of the keyboard and compare it with the new one. If the’re identical you can replace it. Just make sure to document it and share it for the benefit of others :).
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Ryan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 31
Altijd: 748
