Ga door naar hoofdinhoud
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Vragen Bekijk alle
Does not go to sleep when lid is closed
Hello,
After replacing the battery on this computer, the computer does not go to sleep when the lid is closed. Everything else works fine. Maybe it is a damaged hall effect sensor?. What would most likely have been damaged in the process of replacing the battery that would have caused this? How would I go about fixing it?
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi there,
Is the display setting set to always on?
Was dit antwoord nuttig?
1 Opmerking:
No. No software settings were changed after the battery was changed, including the display settings. It used to go to sleep before.
door
Voeg je antwoord toe
Albert Einstein zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 46
