Can I use an Early 2013 rMBP display with a Late 2013 rMBP?
Hi,
I recently purchased a used 15” rMBP and apparently Did I accidentally remove a backlight power connector?.
This rMBP seems to already be using a display from a different model of rMBP as the webcam doesn’t work because the webcam connector is small but the socket on the logic board is large. I guess this is a display from an early 2013 rMBP.
So my question, to double check, is will a display from an early 2013 work with a late 2013 MacBook Pro? I understand the webcam (and therefore auto-brightness) will not work, but I don’t use these features anyway. The reason I’m considering this is that a new early 2013 display is a whopping £285 cheaper than a new late 2013 display!
Is dit een goede vraag?
