Ga door naar hoofdinhoud
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 Vragen Bekijk alle
Is the microphone in the 2017 21" compatible with the 2017 27"?
The mices look quite similar, but I am not sure they are in equal lenghts. I have had no luck the past 6 months to source a microphone, but may have the opportunity to buy a 21” and use the microphone. Want to be sure before I buy if anybody has any experience
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
First here’s the 27” part 2017 27” iMac 27" Retina 5K Microphone cable, Apple P/N 821-01072
And here’s the 21.5” part 2017/2019 21.5” iMac Microphone cable, Apple P/N 821-01020
Clearly the 21.5” cable won’t work as its shorter and is setup differently!
Was dit antwoord nuttig?
Voeg je antwoord toe
Sonnicham zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 147
