Ga door naar hoofdinhoud
A1418 / EMC 3068 / iMac 18,1 / 2.3 GHz dual-core i5 processor. Released June 2017.
41 Vragen Bekijk alle
iMac won’t turn on after upgrading RAM and SSD
I purchased 2 8GB RAM modules and 1 TB SSD to upgrade my extremely slow base model 2017 iMac. I followed the instructions meticulously, took me about 4-5 hours from start to finish and now the thing won’t turn on at all!
Where do I even start trying to troubleshoot the problem? Everything appears to be reconnected properly. I’m ripping my hair out as I need my computer for both work and school!
Update (08/06/2020)
2 led lights
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I took everything apart again to double check the RAM modules, noticed one appeared to be slightly damaged so I swapped it out with one of my old ones. Put everything back together and everything is working now.
Was dit antwoord nuttig?
Het nuttigste antwoord
Locate the onboard diagnostics along the left edge of the logic board near the fan
What are they telling you?
Score 2
1 Opmerking:
2 lights come on. I can only upload a photo as an answer.
door
Voeg je antwoord toe
Larissa Starr zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 243
