Ga door naar hoofdinhoud
The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
23 Vragen Bekijk alle
Is this a good alternative to an iOpener?
The kit I just ordered to change the battery to my XS Max doesn’t come with an iOpener. I can’t find it on Amazon by itself but there’s one on here by itself that I may buy. I was just wondering if I heated up a wet paper towel in the microwave, placed the warm paper towel in a zip lock bag and sealed it would that be a good alternative to an iOpener? (Or even just a warm regular towel inside a zip lock bag)
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Frankly I would just use a hair dryer or heat gun (variable temp).
A wet paper towel is risky! The water could sneak in! The other factor is it doesn’t have enough heat mass.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
My hair dryer does an amazing job at high! It burns me.
door
Sounds like you need a cooler hair drier ;-}
door
For difficult things to heat up safely, I wrap therm in a clean cup towel, turn my toaster oven on to bake and sit them on top for a couple of hours.
Score 2
Voeg je antwoord toe
TMay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 37
Altijd: 826
