Ga door naar hoofdinhoud
6th generation Android smartphone designed by Google and manufactured by LG. Model LG-H790. Released October 2015.
89 Vragen Bekijk alle
Thermal Pads for Phones
Hi guys, so right now I’m doing a screen repair on a Nexus 5X and I’ve realized that there is a thermal pad on the phone’s screen assembly (see picture). I don’t think I can transfer this pad without breaking it so I was wondering which thermal pad should I buy.
Is it fine to use pads that are for PCs eg. GPUS?
Should I be buying 0.5mm thickness or 1mm thickness?
Are AliExpress/eBay thermal pads fine to use.
eg. ++https://www.aliexpress.com/item/32716660...
++https://www.aliexpress.com/item/32839304...
Thanks.
Is dit een goede vraag?
1 Opmerking:
The thermal pad on the screen is the yellow square.
door
Voeg een opmerking toe
1 Antwoord
If you have a lot of space use 1mm which would dissipate the most heat but if you only have a limited amount of space then go for 0.5mm and I think you should read the reviews before buying the thermal pads
Was dit antwoord nuttig?
Voeg je antwoord toe
Hairy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 254
