Ga door naar hoofdinhoud
A more affordable, purely handheld version of the Nintendo Switch game console, with integrated Joy-Con controllers and a slightly smaller screen. Released September 20, 2019.
Adhesive foam for digitizer
I easily found a replacement digitizer for my scratched one on my Switch Lite (they’re all over ebay and Amazon), but it did not come with the adhesive foam to attach it to the LCD and the case. I can’t seem to find this foam anywhere, though I did see replacement foam for the regular Switch. Is this foam available somewhere or is there another solution for replacing the digitizer?
Is dit een goede vraag?
2 opmerkingen:
I ended up using pieces from the Tesa 61395 card that iFixit sells. I did this for the outer ring of adhesive, the part that attaches the digitizer to the Switch itself. For the inner ring of adhesive, the part that attaches the digitizer to the LCD panel, I was actually able to carefully remove the old foam from my scratched digitizer and reuse it. It actually came off the old digitizer pretty easily when I carefully removed it with tweezers. I couldn’t salvage the outer ring in this way, though.
door
my inner foam tape is barelly sticky, is it supposed to be like that?
door
Voeg een opmerking toe
4 Antwoorden
Try some adhesive tape rather than the foam
Was dit antwoord nuttig?
did you ever find it? i need it aswell
sorry to revive an old question but did anyone ever find any of this foam? Or is Tesa Tape good enough? I’ve got a switch lite digi to replace but the owner already attempted it themselves and binned the old Digi along with the foam so I need to get replacement
1 Opmerking:
The tesa tape works fine.
door
Did anyone ever find the sizing you need? It comes in multiple mm thicknesses
2 opmerkingen:
I think its 2mm
door
Thanks mate!
door
Voeg je antwoord toe
strells zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 1,337
