Ga door naar hoofdinhoud
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
215 Vragen Bekijk alle
'Liquid' like Spots on screen?
Hello,
I decided to try and repair my own iPad and I think I failed. The screen has these bubble like things when I press on the screen. The screen hasn't been dropped and I purchased what I thought was a ‘premium’ grade screen + LCD replacement. My original screen had them too and Im not sure what they are or how to get rid of them. Also I couldn't figure out how to correctly reassemble the home button. It's either significantly lower than before or it gets stuck.
Thank you in advance for answering.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Is the frame bent in any way? I know you said you got a premium display, but where from? If the spot disappears when you lift the screen off, there may be something pushing against the LCD causing this pressure spot.
Was dit antwoord nuttig?
2 opmerkingen:
I bought it from mobilesentrix. From what I could tell it isn't bent at all. The pressure spot is more apparent when pressing the home button.
door
@cfphonerepair I order from Sentrix myself. there could be a possibility of a defective display but seeing as it was an issue before, there's gotta be something pushing up on the screen. I know this may sound silly, but did you install the new screen and not the old one by mistake? I've done that before a couple times XD
door
Voeg je antwoord toe
Cindy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 165
