Ga door naar hoofdinhoud
De Nintendo Switch is een draagbare spelconsole die via een dockingstation op de tv of onderweg kan worden gespeeld. Uitgebracht op 3 maart 2017.
micro sd card reader not working even after replacement
my micro sd card reader wasnt reading sd cards. so i purchased a replacement and repair kit from this website. followed directions and it still doesnt work idk what could be the issue but nintendo online repair is closed still and im just really annoyed things just cant work.
Is dit een goede vraag?
Score 7
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Same thing as I had for 2 years, for me it was that you need to make sure the connecter is fully pushed in. If it still doesn’t work it may be a faulty socket on the board (don’t quote me on that).
Was dit antwoord nuttig?
Score 3
I was in the same situation. After closer inspection, my socket was bad. I had missing pins. So I had someone replace it for me and it started working again. Replacing the socket requires micro-soldering, beyond my skills.
Score 2
1 Opmerking:
I'm in the same situation as you who fixed yours and how much did it cost
door
I am also in the same situation. I did notice that while the switch is on, I can get the switch to detect the replacement reader if I press down on the connector at a certain angle. But I need a more permanent solution. I can’t be playing with the back open like that.
Voeg je antwoord toe
Luke Priore zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 44
Altijd: 2,100
