Ga door naar hoofdinhoud
Model numbers JSN-L21 and JSN-L42.
36 Vragen Bekijk alle
phone heating and battery draining
i m using honor 8X 4GB 64GB varient.my phone gets heated up and battery drains fast even when i use to watch youtube or web searching.n heat comes from near the camera portion.help me out of it as soon as possible.thank you
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
This might be a signal of some sort of hardware error. Have you ever tried booting the mobile in safe mode and perform the usual tasks that make your phone hotter(watch youtube in your case). Also, don’t forget to check if any app installed on your app is using your mobile/wifi data in the background. A weak signal can also cause your phone to drain your battery faster and generate heat as well.
Was dit antwoord nuttig?
Score 2
Go into settings and battery to see what applications are primary users. Then adjust those apps in polling frequency - or even uninstall them. Other primary possibly unneeded battery users: Bluetooth, GPS (Especially indoors), WiFi when none nearby. Screen brightness. Volume.
I searched a little bit online.
Try the following steps to cool your phone down again,
1. Remove the phone’s case
2. Switch on airplane mode to disable all connectivity
3. Move it from direct sunlight
4. Direct a fan at your phone (but don’t put it in a fridge, freezer, or cooler)
5. Reduce the display brightness
Once you’ve done this, try the following to avoid further overheats:
1. Use Battery Saver mode
2. Clean up your phone to remove junk files
3. Reduce Wi-Fi, Bluetooth, and GPS use unless needed
Not only should your phone stop overheating again, but the battery should last longer! Beyond overheating, there are plenty of apps you can use to check if your Android is functioning properly.
  • My uncle present Honor 8x for me in 2019, and i dont have any battery & heating issues so far today .
  • I recommend don't upgrade your android versions
  • Because so many problems are arrived after you upgrade the android versions ,so don't do this....
1 Opmerking:
I d upgrade my own and My phone use to turn off by itself when ever connect to WiFi or mobile data and battery drain easily
What can I do?
door
Working and phone power on phone but Android window seen but not opening 😔
Voeg je antwoord toe
Raj rishi Nath zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 18
Altijd: 1,462
