N64 that's producing a bad video signal.
Hello,
I was given an N64 that's producing a bad video signal. It's very dark and it seems like its too red.
My first thought was an issue with the capacitors. I replaced those, and the picture is the same. I probably should have done more research before I did that. Then I thought maybe it had something to do with the multiout port so I cleaned the pins on that. I also cleaned the cartridge port while I was at it.
Then I started plugging it into different TVs. On two different CRTs I'm getting a similarly compromised image. However for some reason when I plug it into my elgato video capture device, it seems almost normal (maybe a little dark).
Here's a list of everything ive done so far
Replaced Capacitors
Cleaned Multiout Port
Cleaned Cartridge Slot
Tested with 2 different sets of OEM AV Cables
Here's a comparison of images from the different displays I've had this connected to.
Any help would be greatly appreciated.
Is dit een goede vraag?
