Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
20 Vragen Bekijk alle
Cracked screen, remove to see if LCD is broken?
Before I order the digitizer is there a way to know if I need to also replace the LCD? Should I remove the broken digitizer before ordering parts?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Well if only the front panel digitzer is broken you should get apple logo or any image when you turn it on or charge it.
If you get no image on the LCD what so ever i would try to charge it while using a USB voltage meter. You can find it here: USB Mini Voltmeter . You should get more the 1A while charging and that means its charging fine. If its charging fine but you dont get anything on the screen i would assume the LCD is broken as well.
USB Mini Voltmeter to test chargers and charging functionality. Afbeelding
Product
USB Mini Voltmeter
$9.99
Was dit antwoord nuttig?
Voeg je antwoord toe
Garrett ewald zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 57
