Ga door naar hoofdinhoud
The first Android smartphone from Google, the Pixel XL (Model Number: G-2PW2100) was launched October 20, 2016. It has a 5.5-inch AMOLED display, 3450 mAh battery, and 32 or 128 GB storage options.
67 Vragen Bekijk alle
Phone on but screen black
Phone turns on but screen is black after I dropped it on kitchen stone floor. Good protector cover. Screen not cracked. I tried several YouTube suggestions i.e. Power+Volume up/down etc. Any suggestions? thank you.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sounds internal. The power supply for the screen may have been moved because of the fall. Unless you have some phone repair experience+the right tools, taking it to a technician should be the best solution.
If nothing is broken or needs to be replaced, repair should come cheap, too.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Wow, quick response and good suggestion. I have taken phones apart and have the tools, but have not worked on this old Pixel. Can you suggest what I need to get to repair/replace the power supply for the screen? Thanks again for your help and quick response Med_tech, appreciative.
door
If it isn't broken you should be able to just slide it back into place.
If it is, it would be a real hustle trying to find the specific spare part. In that case, a specialized tech should probably intervene.
door
You are right. I will have to find a tech to look at it. thanks!
door
Voeg je antwoord toe
Mary Brady zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 369
