Ga door naar hoofdinhoud
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
124 Vragen Bekijk alle
Soldering flex cable to logic board
Can you use silver solder to attach the flex cable to the logic board? I have solder-it which is a silver based solder paste but I want to make sure it will work without damaging anything. Everything I’ve looked up says to use SMD solder, but I can’t figure out what the difference is?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
SMD solder paste has a low melting point. Silver solder is too high and will damage your logic board.
PROPERTIES OF SOLDERS
What are you soldering? Please post some pics so we can see what you are upto and explain more fully.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Rae Taylor zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 207
