Left DIMM slots not working after High Sierra upgrade
This is not my first run in with this. The first time it happened I assumed something had borked on my logic board, as I had been tinkering around with it a lot (replaced the GPU and CPU). I figured I had been indelicate somehow. So, I purchased a new logic board on eBay. I slapped it all back together and used a temporary hard drive, as I knew I’d need to upgrade the firmware to recognize my existing partitions (I was running Mojave, so they’re APFS). I started off installing Mountain Lion, and it recognized the RAM in both slots. After installing High Sierra, the left side no longer recognizes DIMMs in either position. My theory is that this is something to do with the firmware update required to install High Sierra. Has anyone else seen this?
None of the networking devices, WiFi nor Ethernet, have worked in any install or firmware version with this logic board, but I suspect that’s an entirely separate issue.
Update (06/28/2020)
Just to clarify, in both scenarios it would recognize 16GB of RAM, but only if both 8GB DIMMs were in the two right slots.
As for the DIMMs, they are 8GB each. Here’s a shot with relevant info:
The networking issues are indeed on the replacement board. The seller has a good return policy, however. This entire ordeal makes me think there’s nothing wrong with my original logic board. Or wasn’t, until I accidentally broke the power button connector off the logic board.
Is dit een goede vraag?
1 Opmerking
Can you give us the details on what your SO-DIMM's are: Make and specs as well as the size.
I've setup a few 2010 models with 16 GB of RAM so I know it should be working.
As far as your network issues that should like a much deeper issue. Is this the original or replacement logic board? If it's your replacement is bad.
door Dan
