Keyboard replacement guide - where to find?
Could someone point me in the right direction of where to find the guide to replace a1708 mbp keyboard? just cant seem to find it. thanks
Is dit een goede vraag?
The reason you can’t find one is Apple is servicing the Butterfly keyboard issues for free! They are replacing the full uppercase assembly transferring your display, logic board and bottom cover over.
Keyboard Service Program for MacBook, MacBook Air, and MacBook Pro
You can do the same using one of these:
Even if you wanted to replace the keyboard alone is not an easy job as there are riveted in! So far I have not found a source for them either.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 795
3 opmerkingen
unfortunately I have the same problem and Authorized Apple Service Provider wont help
door yuwonowibowo
@yuwonowibowo - Fire off an email to big Tim tcook@apple.com. Tell them the service providers name and the reason they refused to fix your system under the extended warranty program. As long and you didn't damage the physically keyboard they should fix it! Don't let this slide!
Otherwise you'll need to replace the full uppercase as I laid out below.
door Dan
thanks for the reply Dan
door yuwonowibowo
