Ga door naar hoofdinhoud
Guides on how to fix and or repair common issues on the 1995-2002 3rd generation Toyota 4Runner. The 3rd generation 4Runner is a body-on-frame truck-based SUV with Independent Front Suspension (IFS) and solid rear axle with coil springs in the front and rear.
16 Vragen Bekijk alle
Ignition by-pass 1996 Toyota 4 runner - RESOLVED
My 1996 Toyota 4 runner SR-5 (V6) automatic tranny, has an intermittent starting problem. I could spend a fortune to a auto electrician or I could do an ignition by-pass.
I have looked this up on google and I can many, many different answers.
The one which seems the simplest is to run a wire (4 gauge) from the positive stud of the starter solenoid to the positive stud of the battery with a MOMENTARY push button switch in between.
However, I’m not experienced with this kind of thing and I’m worried about further damaging the SUV.
Any advice gratefully appreciated . Particularly as to what MOMENTARY push button switch to buy. The starting system seems to draw 175 amps , so I’ll need a switch that can handle this large amperage
Any advice gratefully appreciated.
Thank you
Update (06/27/2020)
Hello all, I discovered the problem, quite by accident. The 4 runner which I just bought had the alarm system set up to shut off the ignition system. I had been accidentally, pushing the wrong button on the alarm fob. PROBLEM SOLVED ! Big relief.
Is dit een goede vraag?
2 opmerkingen:
Hello Allen Barr,
Thank you very much for your post. Obviously, you know what you are doing. If unable to solve the problem , I’ll use your method.
door
Giidvto know.
door
Voeg een opmerking toe
1 Antwoord
That is not the way to do it. They don't make a direct starter button that would take that size of wire and carry that many amps. If you don't want to actually find out what is wrong with it. Just buy a start button and hook power to it from run power and then to the start relay. It's set up so you don't melt wires or start a fire. If you want to fix it check for power out of the ignition switch in the start position, it then goes through the neutral/clutch safety switch depending on which transmission you have. Then through the starter relay and then to the starter solenoid which is part of the starter. This is around a 14 gauge wire. My recommendation is to get some wiring schematics and trace the problem. Find a friend who understands electrical work.
Was dit antwoord nuttig?
Voeg je antwoord toe
Richard Whiting zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 47
Altijd: 1,993
