Ga door naar hoofdinhoud
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Vragen Bekijk alle
HDD temp sensor connector type
Hello,
  1. I have lost my temp sensor cable and i want to make my own sensor with a 3904 transistor but I need to buy the connector and I don’t know what type of connector is it so i can search for. Can you help me with the connector type?
Is dit een goede vraag?
2 opmerkingen
Can you tell us the exact model 21.5 or 27" and what year. That way we get you the proper part info.
door
It is late 2009 A1312, 27” Imac, EMC 2309, and the HDD is Seagate. My issue is the connector that plugs into the logic board, not the one that plugs into the HDD. The picture above shows the exact connector that I need that connects to the logic board.
thanks,
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
There were three. One built for Hitachi, Seagate and Western Digital hard drives. Please tell us you exact machine and what original Apple hard drive it had.
UPDATE
Sometimes the 2009 does not need the Thermal Sensor to preventive run away fan. Did you try it after you changes the hard drive?
iMac 27" Hard Drive Temperature Sensor
https://www.powerbookmedic.com/iMac-27-H...
24" iMac Hard Drive Temperature Sensor
http://www.powerbookmedic.com/24-iMac-Ha...
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for the update. Mine does require a temp sensor.
I know I can buy a sensor cable but I was wondering if I can find that type of connector so I can build my own temp sensor. I just need to know if that type of connector can be bought from somewhere, or is proprietary to Apple and can't be acquired anywhere else?
door
Click on the links I gave you.
door
Voeg je antwoord toe
Andy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 92
