Is there a way to check if my engine is getting fuel?
I can hear the fuel pump running but I’m not sure if I’m getting fuel to my motor. How do I check
Is dit een goede vraag?
It might have a fuel pressure test port in the line. If it doesn't you will have to unhook the line and put a fuel gauge in the line. Shops carry those sets but they run in the hundreds of dollars. If it has a test port you should be able to rent one from autozone, o'Reilly's, etc. You should also verify that you have spark.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 319
