Ga door naar hoofdinhoud
Announced in March 2015 and released April 10, 2015, the Galaxy S6 Edge is the curved-screen version of Samsung's newest flagship smartphone.
237 Vragen Bekijk alle
Device not charging or powering on.
I have an S6 edge that is not charging. When you plug it in it says charging with something like 0.3A. I transfered the main board to a working samsung s6 edge but still the same.
Then I replaced the power IC and charging IC and also the same.
When I charge it, the battery logo on my display stays empty. It doesn’t even say %. When I start up the phone it shows the samsung logo and powers off. I read the older samsung phones are known for emmc failure. Anyone have any tips or fixed this problem before?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Seems you have done enough efforts to get you phone alive. But, have you tried a battery replacement. May your phones battery is old enough to hold the charge. Here I must include, no matter how recent you have purchased the battery/phone, modern Li-ion battery loses the charging cycle rapidly if you charge and recharge it rapidly. As per the “emmc failure” , it has nothing to do with charging. However, it can cause you Galaxy get hotter while using or charging it.
Was dit antwoord nuttig?
1 Opmerking:
Tried 2 batteries. One from a working s6 edge. I put the mainboard in the case and a newly bought battery.
door
Voeg je antwoord toe
KWH zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 842
