Ga door naar hoofdinhoud
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
20 Vragen Bekijk alle
icloud bypass ipad A1396
how to bypass icloud activation lock??
Is dit een goede vraag?
Score 9
1 Opmerking
I have this problem also
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
You can't. The only way to remove iCloud is the original owner with a receipt can take it to an Apple store and they will reset it. Or if you bought it from someone they will have to remove it. They don't need to be there in person they just need to remove it from their account. Other than that there is no way. The FBI just spent millions of dollars to get some people from I believe South Korea to crack the code.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Himchuli Powerlink zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 4,767
