Ga door naar hoofdinhoud
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Vragen Bekijk alle
Why is my iMac still running but the screen is off?
My iMac late 2009 is running like applications and such will open but the LCD screen is black.
I have put new thermal paste on the GPU, I have made sure all cable connections are tight, and I have even recalled the GPU solder.
One thing I might think is causing it is that the GPU temperature cable is unplugged because its being a pain in the but to install. But, I’m not sure it is that because I have my fans running at high speed because HDD temp cable is unplugged because I recently upgraded to a SSD.
Any answers are greatly appreciated.
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Are you able to see an image on an external display? If you are then the GPU is fine. This then points to your internal display having issues. Using a flashlight placed on the display at a sharp angle can you see the faint image off your desktop and its icons?
You need to fix the fans, you really need to get them connected and working. Here’s what you’ll need for your SSD OWC In-line Digital Thermal Sensor for iMac Late 2009 - Mid 2010 Hard Drive Upgrade
Was dit antwoord nuttig?
2 opmerkingen:
I don't have an external display currently or at least one with a mini display port, what can I do?
door
A HDMI or VGA monitor will do using a dongle.
door
Voeg je antwoord toe
Reece Clegg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 42
