Ga door naar hoofdinhoud
The Samsung Galaxy A40 was released in April 2019.
28 Vragen Bekijk alle
Samsung A40 stopped charging yesterday following him dropping it.
Hi, my brothers Samsung A40 stopped charging yesterday following him dropping it, resulting in the phone being bent. The phone is now completely dead and he has a replacement in the mail. However, he doesn’t want to lose all of his images and contacts. Any suggestions?
Thanks.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
do as in the movie. or press the phone on the back in the fingerprint area. hold and connect the charger
https://youtu.be/SS_nAF4tMFk
Was dit antwoord nuttig?
Score 6
3 opmerkingen:
OMG, this worked ! Thank you Jacek Sopel.
door
'or press the phone on the back in the fingerprint area'
Genius, worked
door
It really worked my phone started charging
door
You have problem with:
# Charging dock (Charging port or FPC connector) - needs replacement.
# Main flex cable - needs replacement.
# FPC connector on the motherboard - needs repair from technician.
Samsung Galaxy A40 - does not charge - how to diagnose the problem
Score 1
He can open it up and check the connections for the battery and the charging port, a connection could have been knocked loose. He could also connect a battery to the phone and extract the data or take the battery out and charge it with a battery charger you can pick up on Amazon for 20 dollars
do you have to return the phone? If so will you get in trouble if you open the phone? You can have a repair shop take the back cover off and charge the battery and get the data.
Voeg je antwoord toe
Chloe Stephens zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 54
Altijd: 3,667
