Startup Keyboard commands not working
A while back the T key on my Mac stopped working unless I pressed really hard. Soon the E key stopped working too. Eventually the column of E,D, and C and T,G, and B all stopped working. I tried reseting the SMC which seemed to reset but didn’t change anything. I then went to reset the PRAM. I never heard a second startup chime and MacOS just booted up only it was running at like .2 fps. The only way I was able to fix it was by disconnecting the battery and power cycling the machine. I am also unable to use ANY startup commands including recovery mode, target disk drive, boot selector, and most importantly hardware check. Any help is greatly appreciated.
Is dit een goede vraag?
2 opmerkingen
You'll need an external USB keyboard and mouse to get the system working enough to run diagnostics. Restart your system this time pressing the D key. Tell us what you get for errors.
Did you have a liquid spill or sit your system down on a wet surface at some point?
door Dan
I’ve tried with both a USB and Bluetooth keyboard without success
door fellerrm
