Ga door naar hoofdinhoud
Released June 2017, identified by model number: SM-J530F
Galaxy J5(2017) disassembly - power switch fix
I was trying to fix a wet Galaxy J5 (the buttons and the touchscreen were broken) so i disassembled it, and i started cleaning the contacts (that were full of water and sand) with some alcohol. Now I don't understand how the power button works. I don't understand were it connects to the main board, but i noticed that one piece that seems to connect the power button to something else is broken. I don't know where to find a replacement. I've never disassembled a smartphone before so i don't really know what i'm doing but i just wanted to try. Anyone has any tips? I'll post photos of that power button.
In this image there's the back metal cover with the switch itself:
In this image there's a little cable with two contacts, i don't know where it's attached but i'm sure it connects to the power switch on the back cover. That little cable is broken, one of the two contacts is ripped off:
Sorry if i was not clear but i don't know how to explain this, also sorry for my bad english. Thank you for reading this.
Is dit een goede vraag?
Score 1
1 Opmerking
got same problem but it will not fix it
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I found the the power button on Ebay. And a couple of videos on how to take the phone apart and put it back together on YouTube.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Alessandro Vanuzzo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 18
Altijd: 1,090
