Ga door naar hoofdinhoud
A high-performance gaming console created by Microsoft, featuring 4K visuals. Model number: 1787
24 Vragen Bekijk alle
Weird eject issue and device control not working
So this is actually two separate issues:
  1. I am having a strange issue with my One X where the eject button is intermittently not working, but when it is not working, the disc will eject if I push on the front of the top of the case. I would assume there’s some shorting issue going on, does anyone know what part I would need to inspect and/or replace to fix it?
  2. When I received my X back from being repaired by Microsoft, I noticed that the device control feature no longer works. It didn’t bother me enough to send back again for another 2-3 weeks, so I figured now that I have the time I’d fix it myself. It worked before and I used that feature to turn my TV on and off with the Xbox, and now it is not working. It will say that it has recognized the TV and can control it, but it doesn’t actually work. I have tried it with several TVs to the same result, so I know it is an issue with the Xbox.
If anyone has any insight on either of these issues, I would greatly appreciate the help. Thank you!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Send it back, opening the Xbox is going to void the warranty and if you got it back with a different problem you absolutely should send it back.
Was dit antwoord nuttig?
1 Opmerking:
I know that it will void the warranty, but the warranty is long expired. I probably should have sent it back, but they told me it would be gone for another 3 weeks after it had been gone for 4 weeks for the previous repair. It didn't bother me enough to wait that long. Now that I have free time (yay layoffs) I figured I'd take a crack at it.
door
Voeg je antwoord toe
Eric zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 123
