Ga door naar hoofdinhoud
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
171 Vragen Bekijk alle
Xbox original don't read games but dvd reader works on other console
Hi, I’ ve an Xbox classic that I’ve removed clock cap because it had realesed acid on motherboard and I cleaned the part and done some solder traces near clock cap. The problem is that console don’t read games. I thought that wat the dvd reader but I’ve tried an other dvd rom but nothing, instead its dvd reader works fine on another Xbox. Console tries to read but after go to the clock screen. Thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The laser is known to fail, to the point it’s somewhat common for these to be temperamental even with a known good drive. It tends to be more of an issue with the early Thompson drives, but the Samsung SDG-605 -006 is almost as bad. You’ll need to find a new DVD drive, or a compatible laser. In SOME cases, you can clean the lens, but this is questionable at times as the issue may come back, and it may be too far gone.
You want to avoid the Thompson drives (these are known to be junk). Try and avoid the SDG-605 -006 due to the CD-R issue; the -005 is okay. If you can find the Hitatchi drive, buy it if you can pay for it. These are relatively rare as they’re pretty much only used in the 1.6 console, but these are far better than the others. However, if you want to play legally owned backups the Samsung -005 tends to be the “go to” drive.
Since these do not care about the optical drive “matching” like the 360/One (even then, Live has not worked since 2010 which would be the only reason to care as not matching can result in a console ban which will never happen today), find a working Philips or Samsung drive that is tested, unless you’re getting it for practically nothing. They still have issues, but they aren’t as expen$ive and rare as the Hitatchi used in the 1.6 systems. Refer to this guide to change the drive.
I get it with these - I got 2 for $40 (1 was ready to use and the other has this issue, other than one having a prenatal controls with a PIN but seeing as this is the “master PIN” era anyone with Google can find NBD) and it took a while to find a reasonably priced laser since I have the Samsung drive in that one.
If that doesn’t work, it’s likely an ATA logic issue that’s isolated to the optical drive, but not the hard drive. Usually, ATA logic causes it to display a service error, but it can happen in odd ways. You normally get a service required error like this with a matching error code:
Was dit antwoord nuttig?
Score 1
6 opmerkingen:
Hi, thanks for the answer but I've tried 4 dvd rom(2 philips, thomson and samsung) that thy work on 2 other xbox..ony in this console they don't work. could be hd broken or other? thanks.
door
@shinobi76 The hard drive would cause a service required message. It may be an ATA logic failure if even the high failure rate Thompsons aren't causing an issue. It took me 14 months on and off to find one that was compatible.
These drives can be touchy, especially the Thompson. Hence why I waited to fix my bad laser Xbox.
door
Solved. After I’ve removed clock capacitor at start the console goes to the data clock screen instead of normal menù. Press A button on the pad to start the games on your dvd drive. It was very simple. I thought that dvd reader wasn’t working but was a simple a litte more passage to do to start games. Thanks for answer anyway.
door
@shinobi76 Both of mine are still holding time, but I have 2004 units. They lose the time if they sit too long, but it's maintained with an electrolytic capacitor.
door
Hi, so I could replace it with an electrolytic capacitor? Thanks in advance.
door
1 commentaar meer tonen
Voeg je antwoord toe
Rosario Mangiagli zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 1,353
