Ga door naar hoofdinhoud
Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
873 Vragen Bekijk alle
iPhone 8 bad audio during phonecalls
Haven’t had an iPhone 8 with these symptoms. People can’t hear me clearly during phonecalls whether in handset or speakermode. Sounds like I am far away or voice is cut off so I sound like I’m stuttering. Using voice memo voice works perfectly. My colleague changed the charging dock and it was fine for a day and the problem returned.
Audio IC related problem or something deeper perhaps. Any advice would be appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Can Siri understand you? If she can and as you said voice memos work fine I would be leaning towards a parts problem. When I am faced with similar problems I would put the logic board into a known good housing and screen. If it acted the same you know you have a board problem. I have not uncounted an iPhone 8 that needed an audio IC repair but anything is possible.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
KWH zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 98
