Ga door naar hoofdinhoud
Acer's 15.6 inch E5-571 series laptop manufactured in 2014.
29 Vragen Bekijk alle
I need an internal blue ray drive.
I have found a blue ray drive that states it fits E5-571 and E5-571G models but I have a E5-571P model. Will this drive work for my model as well?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi Patrick French
If your current laptop has a optical drive,
and yes, you can do a swap.
System should detect the new optical drive.
  1. Eject the current drive tray
  2. Power Off the laptop
  3. Unscrew the optical drive screw, normally held by one screw.
  4. Pull out the drive, by holding on the ejected tray
  5. check if there are any rail brackets, if so remove and transfer to the new drive.
  6. install the new drive and screw to hold it.
  7. power on and test.
Was dit antwoord nuttig?
Voeg je antwoord toe
Patrick French zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 44
