Ga door naar hoofdinhoud
The Samsung Galaxy A10 is an android smartphone developed by Samsung Electronics. It was released in March 2019.
69 Vragen Bekijk alle
I dropped my phone in water
my phone has been dropped in water as a prank by my friends. now, the phone’s screen is black, I dont, know if I can remove the battery or not.
It works, it’s just that the screen is black considering i get the vibrations for notifications
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It sounds like you damaged the screen. You will need to replace the screen with frame. You will need to take the back cover off and remove the Phillips screws and take the mid frame off (this is not the same frame for the screen). The you can unhook the battery. You can check the board for corrosion and clean it with alcohol and a soft brush. Ifixit has some repair videos and you can also find more videos on YouTube. You will also need a precut adhesive for the back cover. I hope this helps
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Issacpe28 2.0 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 398
