PS4 WLOD after plugging into a HDMI booster + missing component
After plugging my PS4 Slim (F-chassis, board SAF-003) into a HDMI booster, I immediately lost signal. I’ve tried several monitors and several cables and it has definitely gone kaput.
I’ve tested the EMI filters and all are OK (continuity to pins and no continuity between pins). I’ve tested all the diodes and they seem to be fine, and no obvious shorts anywhere in the circuit. Readings attached. Is the encoder chip probably knackered?
Also, unfortunately I shorted the right-most 5-pin SOP package in the image while testing, and had to remove it for the board to start up again. Has anyone got any idea what this component is/what I can replace it with? (Update, I’ve found that PSDevWiki has listed all the regulators used in the PS3 here - the PS3 HDMI circuit looks really similar to the PS4 circuit - I may eat my words but I think this part is an NCP511SN25T1G SOT-23-5 LDO, as this is the only one listed that steps down to 2.5V).
Thanks in advance!
Is dit een goede vraag?
