Ga door naar hoofdinhoud
Model M8407 / 550 or 667 MHz G4 processor
20 Vragen Bekijk alle
My hinge is super stiff on my TiBook G4 Onyx
Hello, I am new to the forums. I have an old TiBook G4 that I started using again after years of sitting in my closet. I used to use it a ton about 8 years ago I never remembered the hinge being that tight. Is there an easy fix, or do I need to do more extensive repair?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Carefully taking off the hinge covers (2 screws each) you can gain access the the hinge screws loosen them to see if the alignment is just off, retighten if not better you’ll need a cotton swab and some WD40 carefully spray the WD40 into the red cap to make a small puddle. dip the cotton swab into it (not too much!) and wipe the exposed clutch spring move the lid a few times and try a bit more oil it doesn’t take much!
Was dit antwoord nuttig?
Voeg je antwoord toe
ClassiMacYT zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 176
