Ga door naar hoofdinhoud
Google's 2nd-generation Pixel XL sports a 6-inch P-OLED display with rounded corners. Available in 64 and 128 GB storage configurations, and in two colors: Just Black and Black & White. Released October 19, 2017.
72 Vragen Bekijk alle
Volume Button Flex Cable and Bracket installation guide
So I bought the Google Pixel 2 XL Power and Volume Button Flex Cable and Bracket from ifixit but couldn't find any detailed guides to do the same. My question being is removal of motherboard required to install this part? Or it can be slided out as is?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi there, I just did this last night. You should be able to use an iFixit pick to pry up the board a little bit and slide the bracket out. It is glue down, so you’ll have to slowly work at it a bit to get it out without breaking it.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Vibhav Rao zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 8
Altijd: 130
