Ga door naar hoofdinhoud
De eMac was een alles-in-één G4-gebaseerde Mac die werd ontworpen voor de onderwijsmarkt en werd uitgebracht in april 2002. Het was de laatste Mac met een CRT-scherm en werd voor een lage prijs verkocht aan scholen en andere instellingen.
Computer Starts but Screen does not turn on?
So, I have a pretty standard eMac that I’ve kept in good condition, no extra work done to it or anything, and I went to turn it on, pressed the power button, heard the regular noise that an eMac makes upon start up, and the screen doesn’t turn on. Comparing to one of my other eMacs that works, it doesn’t seem to be making any noises that sound different. Plugging in a second monitor reveals that the computer is indeed on and working, it’s just that the screen attached to the unit remains black.
What exactly could be causing this issue, and is there anything I could do to fix the screen on my own?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
That’s usually due to a faulty analog board or flyback transformer. This repair really needs to be handled by someone with the appropriate experience due to the voltage of the CRT and the fact most of these have burned out bleeder resistors. These can hold up to 15-25k volts, which KILLS. Take this to someone who is able to work on a CRT to see if they are willing to take on the job.
More then likely you’re better off getting a G4 Mini to replace this due to the cost likely being about as much as the computer itself. The problem with buying a used eMac is the price of shipping (local only) and a lot of them have CRT screen burn (e is for Education). School districts loved to leave these CRT based Macs at the login or another situation where they gauaranteed the machines would have burn-in due to negligence by the time they retired them for Intel iMacs - granted some didn’t get burned due to IT departments putting screen savers on, but most of these are still affected.
The eMac is not a collectible - but the OS9 boot capable ones are mildly valuable since most are not able to do so. Part of that is they're too common and most of them are EDU spec, which is generally not a desirable trait. Combine that with high shipping cost and you can't really sell them for much and they're a local only purchase. A Mac Mini is not.
Unless you need OS9 support, that’s probably going to be your best bet since PPC Macs are primarily machines people keep around to run legacy applications that are PPC/UB (and in some cases, hardware like older printers with a basic driver in current versions of MacOS, but the utility only works on their iMac G5 ALS for example) or they use something like FCP 1, which REQUIRES an OS9 machine. Get a system that can boot OS9 if you need it and that's why you have this eMac - the Mini does not support OS9 boot but it supports emulation.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Yonni Johnson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 683
