Ga door naar hoofdinhoud
The Google Pixelbook Go is a premium Chromebook from Google, featuring a durable magnesium clamshell with minimalist design. Released in 2019. Model number: GA00521-US.
6 Vragen Bekijk alle
Replace battery pixelbook go
Hi, I read the excellent aryicle explaining how to remove the back cover of a pixelbook go. Since the battery is glued to the back, I’m assuming that the best way to replace the battery is teplacing the whole back cover. Is that correct? If it is, where can one find a replacement back cover? Thank you in advance.
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
2 Antwoorden
Hello! Did you happen to figure this out?
Was dit antwoord nuttig?
It’s extremely difficult to remove the cells from bottom cover so yes, replacing the whole battery/bottom cover assembly is the way to go. You can find cheap parts on eBay etc.
Voeg je antwoord toe
alessandro.gherardi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 1,388
