Ga door naar hoofdinhoud
Commonly named the "Nook Simple Touch," this device was released in April 2012. It is the second generation of Nook e-readers. Model number BNRV300.
2 Vragen Bekijk alle
I'm trying to reset my nook and it won't connect to the internet
I'm using a nook (just the regular black and white, non-backlit base model) and even though I successfully connected to wifi in the settings and it says "connected" it wont let me reset my device. When I go to "erase & deregister device" and try to reset it it gives me a network error saying that im not connected to the network. To clarify, everything else on my wifi works perfectly fine and I've tried restarting the device and forgetting the connection, all of the basic stuff.
Is dit een goede vraag?
Score 1
6 opmerkingen:
Before I can answer, I want to ask, what is the version number of the firmware that's installed? If it's 1.2.2, I could continue to provide an answer.
door
Hi, I hope somehow you see this! I'm having the same issue, the firmware is 1.2.1
door
Hi naiaratta,
You must update your Nook BNRV300 to firmware 1.2.2 before it will connect to the internet.
Please see my answer on this page for more info: I'm trying to reset my nook and it won't connect to the internet
door
@nwantz unfortunately when I connect my nook to my laptop (a non-apple device, running windows 11) it doesnt show up in my file finder
door
@naiaratta With microUSB cables, some of them are "charge only", which will not allow the computer to see the Nook as a file system. Do you have any other microUSB cables you can try to connect the Nook to the computer with?
door
1 commentaar meer tonen
Voeg een opmerking toe
1 Antwoord
I would recommend to check if the following article on the Barnes & Noble website applies to your situation:
https://help.barnesandnoble.com/hc/en-us...
Was dit antwoord nuttig?
Voeg je antwoord toe
Skittlyrainbow zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 39
Altijd: 555
