radio has no am/fm but cd is fine
Here is the mystery on my 05 XC90 where the AM/FM radio was cutting out and now is totally dead. You push radio on button, display lights for a second, and goes out. Obviously it is not a fuse issue as it has power, lights up display and the CD works fine. So I replaced radio display module, same problem, amplifier is dry under seat which I know was a problem for thousands. but this didn’t allow any functions when the AMP fails. I disconnected fuse for AMP and same problem, CD worked, not any AM/FM. I then replaced the rear AM/FM tuner in the rear of vehicle, had active MOST signal, but no change. I disconnected CD, no change, so obviously I have not solved the mystery and having scanned the internet, many had same symptoms, but no answers or solutions were found. So does anyone have any ideas?
Thanks,
Is dit een goede vraag?
