Ga door naar hoofdinhoud
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Vragen Bekijk alle
MacBook Unibody Model A1342
My husband spilled a protein shake on my laptop. He wiped it clean but now my keys on the left are doing duplicates. My caps and shift keys don't work. When I hit the following letters I get the letter f also.
af sf df f
The tab, shift, caps lock is not working either. I can live with this but if I could fix this I would feel alot better.
Is dit een goede vraag?
Score 1
1 Opmerking
I just received the keyboard and everything is working great so far. I have not tried everything but sofar so good. The only thing is there is no light on the keyboard or power button but I can live with that. Thank you guys so much.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
More than likely you will need to replace the topcase. MacBook Unibody (A1342) Upper Case
Please give us the last three figures of your serial number for the exact part.
MacBook Unibody (A1342) Upper Case Afbeelding
Product
$179.99
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
Okay sounds good. The Model is A1342 and serial number is 45110P9DF5W.
door
Apple MacBook "Core 2 Duo" 2.4 13" (Mid-2010) Specs
Identifiers: Mid-2010 - MC516LL/A - MacBook7,1 - A1342 - 2395*
door
Voeg je antwoord toe
Willie Shippen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,910
