Water pump system Ford Escape 2012 25 lt it's coolant close to the wat
It's leaking coolant near the water pump should I change water pump thermostat
Is dit een goede vraag?
More likely to be the water pump itself or perhaps a bypass or other hose nearby to the pump that is leaking. You need to visually confirm what is leaking with an inspection mirror and directing a strong light into the hard to see areas around that pump to see exactly where the water is coming from. There are also a lot of low prices boroscopes that hook up to smart phones these days that can help with tight inspection jobs like this.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 56
