Ga door naar hoofdinhoud
Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
387 Vragen Bekijk alle
Ps4 Cannot reinstall system sowtfware
Hi, My ps4 is broken and need some help with it.
So my ps4 is currently in safe mode with only one option which is Initialise PS4, option 7. So I download the install file. which is the reinstallation for version 7.02.put it on a hard drive and it accepts it. but halfway through installing it, it stops and says cannot reinitialise ps4 with an error code underneath it ( CE-34697-9 ). And then there’s only one option which is shut down
I have tried everything I can. Looked at every video but nothing is helping me and it’s just not working
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Is it less than a year old? Get the console repaired by sony.
If not, replace the HD with a new replacement 1TB or larger one. Then re-install / re-initialise the PS4 system software and it will work again.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Remember the error code before asking. Guessing takes you nowhere.
Score 2
3 opmerkingen:
Sorry just got it. Error Code (CE-34697-9)
door
No text for this particular one, send it in.
door
You probably meant "SU-34697-9", hard drive kaput.
door
Take out the hard drive and blow it out and blow out the ps4 and put the hard drive back in… should take care of the problem
Score 2
2 opmerkingen:
This is exactly what I did and it worked, thank you. I was going to throw in another 1tb I had but this did the trick. Thanks to this advice I got a free ps4 Slim
door
This is true 👍🏾
door
Voeg je antwoord toe
Riley Heka zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 107
Altijd: 17,587
