My dishwasher want run a complete cycle
I have a whirlpool wdta50sahz dishwasher that will not run a complete cycle. It will switch either to sensor mode or just stop about 15 minutes into. The control lock comes on sometimes when it fails running. I've changed out the control panel same thing happens. So I'm sure that's not the problem. I've only used it a year ,bought it 2 years ago.
Is dit een goede vraag?
Hi,
Check behind the kick plate (toe plate?) or the door cover to see if there is a "tech sheet" there.
This will show how to get into the diagnostic mode for the dishwasher.
Hopefully once you run a diagnostic cycle there will be an error code that will help with what the problem may be.
door jayeff
Unfortunately I have misplaced my tech sheet .
door charles carwile
@charles carwile ,
Not sure if this method is applicable to your model but you can only try.
door jayeff
