Ga door naar hoofdinhoud
Sometimes my MacBook Air trackpad freezes. (Trackpad Problem)
Device info : MacBook Air 11-inch Early 2015
Battery Cycle : 170
Hello! I have a question about a problem with my MacBook Air.
When I'm using my MacBook, sometimes the trackpad freezes and then works again, or after the trackpad stops completely, and i get a notification that "No trackpad found" and "Wait for a Bluetooth trackpad to be discovered"
I tried SMC reset, PRAM/NVRAM reset, and reinstalling macOS because I suspected a software problem, but it didn't help me solve it at all.
And this is really an occasional problem, sometimes the screen turns off suddenly while using the MacBook, and when i press the keyboard or touch the trackpad, the screen turns back on and the login window pops up.
The trackpad problem is the most serious and interferes with the use, so i'm writing here to hear from experts.
Thank you for reading! I will be waiting for your good opinion and solution.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If you are only loosing the trackpad and not the keyboard, that points to the trackpad its self MacBook Air 11" (Mid 2013-Early 2015) Trackpad and this guide MacBook Air 11" Early 2015 Trackpad Replacement
MacBook Air 11" (Mid 2013-Early 2015) Trackpad Afbeelding
Product
$109.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Junhyung Sung zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 351
