Ga door naar hoofdinhoud
Repair and disassembly guides and support for wall oven appliances.
11 Vragen Bekijk alle
What is the right glue for an oven?
I have an eye level oven, and the door contains three panes of glass. The innermost glass sheet can be unclipped for cleaning. There are two metal clips, glued on with a silicone type adhesive. They have come off, and I need to reattach them.
The clips are not in the oven body, which can get to 450 degrees centigrade (Pyrolytic) but glass is conductive, and I’m sure it gets very hot anyway.
I cannot find a glue rated more than 300 degrees.
Another alternative is an automotive “liquid gasket” product, but I don’t know if that acts as a glue?
Model: VOGUE Pyrolytic Wall Oven
https://www.tradedepot.co.nz/pyrolytic-w...
Is dit een goede vraag?
1 Opmerking
This question was migrated from https://meta.ifixit.com/Answers.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@ladytech found this
 searspartsdirect I found an adhesive used for ranges and high temp.
Part #W10841140
Sears sells it for $9.01
I believe it is just a silicone sealant for high temp
Glass on oven door swinging free
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
I’m glad you found it. I’m going to save the # for future reference. Hope you healthy and sheltered at home. Don’t forget to wash your hands.
door
Need glue as well for oven that seals the inner glass not outside
door
Voeg je antwoord toe
Michael zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 1,638
