Why did my MacBook Pro switch itself off and won't turn on again?
Hi, I've got a faithful Macbook Pro Mid 2012 that shut down on Tuesday whilst I was working from home. The charger had been plugged in 10 minutes before as the battery was running low.
When I pressed the power button to turn it back on there was no response: the light at the front did not come on, nothing displayed on the screen and no mechanical sound. I tried with and without the charger plugged in.
The battery reader on the side lights up and reads at 40%. This hasn't dropped in over 24 hours. I've tried an SMC reset 3 times. I've also taken the back off, disconnected the battery, held the power button for 5 seconds, plugged the battery back in and tried the power button with no result.
Does anyone have any troubleshooting/diagnostic tips?
Thanks
Is dit een goede vraag?
You'll need to open the system up to inspect the logic board. Do you see any burnt components or staining?
door Dan
Hi, I had a good look at the logic board I can see no visible burnt components or staining. Even though the battery reader is reading 40% (still), when I plug the charger in it lights up green as if it’s fully charged. Is this of any significance?
door Dan
@dgud - Lets get a better view of things here. Install this gem of an app CoconutBattery take a snapshot of the apps main window and post it here one with the charger connected and one with it disconnected after waiting a good 5 minutes Voeg afbeeldingen toe aan een bestaande vraag.
door Dan
