Ga door naar hoofdinhoud
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
It sorta still works? But please help
It used to still turn on but not anymore. It charges though. It fell off my table a few years ago and even though it was closed it snapped in half. It worked like that for a little bit but it doesnt anymore. This system means so much to me and Id love to fix it instead of getting a new one. But Im obviously going to need a new case at least. Please help. Check the pictures attached please
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
From what I can see on the pictures, my guess is that the ribbon cable that goes between the screen and the rest of the device has been damaged.
This because there isn’t really anything that can protect it from tear when the protective case is broken and the ribbon is what holds it together.
What you could try regarding the case is to use super glue to put the broken pieces together, just be CARFUL to ONLY PUT GLUE on the places where it has CRACKED and not to get ANYTHING ELSEWHERE.
If you are lucky and not too aggressive when using the device this will probably work, otherwise, you could look after a broken device on the internet that has a good case.
You could also look if you have anyone where you live that have a 3D-printer and ask them to model and print a new case for you.
So I think you need a new ribbon cable then first try to glue the case together and if that dosen’t work, look for a replacement.
Hope this helped!
// eke0909 :D
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Skye zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 75
