Ga door naar hoofdinhoud
De Nintendo Switch is een draagbare spelconsole die via een dockingstation op de tv of onderweg kan worden gespeeld. Uitgebracht op 3 maart 2017.
707 Vragen Bekijk alle
Why is my switch not turning on?
I recently took out my switch from a few months of not using it and its not working. If i fully turn the switch off by holding the power for 12 secs and turning it back on I can get the switch logo to show up but then it flashes a full charged battery icon in the top left then goes blank. I left it on the charger for a few hours to see if i could get a different result but still nothing after that battery icon.
Any help would be greatly apreciated!
Is dit een goede vraag?
3 opmerkingen:
Try getting the Switch to Maintenance mode: https://en-americas-support.nintendo.com... If this does not work, please message back.
door
When I try to do this i get the nintendo logo then a blank screen.
door
Replaced the battery in the switch and reinitialized it. Was working fine for alittle while but then got error code 2002-3539 when playing a game. Tried the check for corrupt data thing for the game and it says no corrupt data was found. The game was good job! if it matters.
door
Voeg een opmerking toe
1 Antwoord
this same thing happened to me. i thought it was my charger at first but i left it plugged in for a couple hour and it came right back to life. if that doesnt work for you your charger might need to be checked
Was dit antwoord nuttig?
Voeg je antwoord toe
Pat zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 619
