Ga door naar hoofdinhoud
Repair guides for the Huawei Mate 20 Lite Android smartphone, released in September 2018. Model numbers SNE-AL00, SNE-LX1, SNE-LX2, SNE-LX3, INE-LX2.
20 Vragen Bekijk alle
No display on my Huawei Mate 20 Lite
Hi,
I have no display on my phone when I press the power button. I have attached a video of the problem
Your help is much appreciated
Thanks
Is dit een goede vraag?
Score 1
1 Opmerking:
I have the same problem. Did you solve it ?
door
Voeg een opmerking toe
2 Antwoorden
did you break the LCD screen it could need a new screen or battery
Was dit antwoord nuttig?
Hey Adeel ;
I can see the back light is being blocked by full contrast from display . Did it drop hard? was screen replaced ? If it were me I would find a tear-down video and double check any of those ANNOYINGLY small connections . Dunno if it will be a case of reflowing the “lead” free solder with heat . Severe drop can crack mobo tho .
Factory reset procedure should not be bothered with , unless you dont care and are curious if it helps . I dont think that would do anything .
PS ! caveat ! reset may cure accidental screen bright down to zero . In a dark room can you see any hint of images ?
Good luck
Hugh
Voeg je antwoord toe
Adeel Hussain zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,888
